ik heb deze code:
// Function: insertSmilies
// Description: insert smilies for adding into news/comments
function insertSmilies($insert_location, $break_location = FALSE, $admincp = FALSE, $wysiwyg = FALSE)
global $config_http_script_dir, $config_smilies;
$smilies = explode(",", $config_smilies);
foreach($smilies as $smile)
$i++; $smile = trim($smile);
if($admincp){
if($wysiwyg){
// $advanced_smile = "<img alt=\':$smile:\' src=\'data/emoticons/$smile.gif\' />";
// $output .= "<a href=# onclick="javascript:InsertIntoArea('$insert_location','$advanced_smile'); return false;"><img style="border: none;" alt="$smile" src="$config_http_script_dir/data/emoticons/$smile.gif" /></a>";
$output .= "<a href=# onclick="document.getElementById('$insert_location').contentWindow.document.execCommand('InsertImage', false, '$config_http_script_dir/data/emoticons/$smile.gif'); return false;"><img style="border: none;" alt="$smile" src="$config_http_script_dir/data/emoticons/$smile.gif" /></a>";
else{ $output .= "<a href=# onclick="javascript:document.getElementById('$insert_location').value += ' :$smile:'; return false;"><img style="border: none;" alt="$smile" src="$config_http_script_dir/data/emoticons/$smile.gif" /></a>"; }
}else{
$output .= "<a href="javascript:insertext(':$smile:','$insert_location')"><img style="border: none;" alt="$smile" src="$config_http_script_dir/data/emoticons/$smile.gif" /></a>";
if( isset($break_location) && $i%$break_location == 0 )
$output .= "<br />";
}else{ $output .= " "; }
return $output;
deze code komt van cutenews en ik ben niet echt heel geweldig met php, ik weet dat de fout in deze regel zit:
de foutmelding is dus Division by zero, oftewel $break_location is 0, maar hoe los ik dit op? Ik heb er niet zelf aan gekloot waardoor deze fout kon ontstaan en er is ook niks mis met de uitkomst, het enige is dat ik zo'n 10 keer de foutcode:
Warning: Division by zero in /usr/home/khinside/domains/khinside.gethost.nl/public_html/
cutenews/inc/functions.inc.php on line 469
tussen iets heb staan, verder werkt het script gewoon
helpie please??
