WLM 9.0 BETA
Geplaatst op: 28 Nov 2007, 20:43
Ja mensen 8.5 is nog maar net een paar maand officieel of Windows Live Messenger 9.0 BETA is alweer uitgelekt.
Hieronder het volledige bericht van Mess.be
Mess.be schreef:
It was bound to happen: a Thai blog called n-blue has posted screenshots of Windows Live Messenger 9.0 Beta0 illustrating some of its new bits. Because a picture says more than a thousand Thai words, I'll briefly comment on them:
- The graphical user interface of 9.0 doesn't differ from the current 8.5 version, but the About window proves that you're using Windows Live Messenger BETA Version 2009 (build 9.0.1407.1107).
- The SPIM reporting comes in the form of a right-click menu item which blocks a contact and reports it as a spammer. We have yet to unravel the mechanics behind the feature to judge its efficiency, but I assume that it could work out nonadvantageous for a contact who accidentally runs into a Messenger worm.
- In the options menu, you can configurate the sign in at more than one place feature. Those who had their worries rest assured, you can still sign yourself out when logging in somewhere else, or -and this is new- stay signed in everywhere. You can also (re)name your current "place" (read: system) as it would appear in Messenger.
- The menu to change the default Messenger Sounds has become easier to use and an ever important "Mute all sounds" option has been added for those who like to work in a silent environment. From the same menu, you can change your signature sound which plays back every time you sign in, to either one of the default ones or a custom one (maximum 5 seconds) extracted from one of your mp3s or other audio files using a handy, built-in sound editor.
- Other new features like Animated Display Pictures or hyperlinks in Personal Status Messages are not illustrated in these particular screenshots. UPDATE: After reading this, n-blue added an extra screenshot showing how one or more links in your personal status message automatically become clickable. And although static, the screenshot also shows an animated gif being used as display picture. Note how animated images with dimensions smaller than 96x96 pixels aren't enlarged, but instead are centered in the display picture area surrounded by a white border.
Somewhere in the Thai post there's a link to a forum post, which in turn links to the supposed Beta0 build. The filesize being only 16.8mb, I don't really trust the download UPDATE: n-blue assured us his mirror is free of viruses and malware. I also found a Chinese blogger who links to the digitally signed MsnMsgs9.0Beta.msi file...
Let me remind you that we DID NOT leak the build ourselves but simply found it out there, very easy to get. We were sent the build by many our most generous visitors a few minutes after it had been released last night (and thanks for that guys), but it is only after we've seen it posted at a few locations that we shared the already public links.
If you decide to download it from somewhere else after all (check the source of this post for starters), you'll be doing it at your own risk (be aware that installers can be tampered with) and at the risk of suspending the 9.0 Beta, thus spoiling all the fun.
Downloaden kan op de volgende plekken:
Ja de links gaan via een proxy omdat ik WLM 9.0 BETA vond op een private torrent tracker en dus de mirrors snel van mastaline.com heb gehaald met een proxy
Is al gefikst! De links gaan niet meer via proxy en werken normaal!
[Laatst bewerkt door DayDreamer op woensdag 28 november 2007, om 20:51]
Geplaatst op: 28 Nov 2007, 20:45
LOl ty 4 sharing.
Zo ff proberen.
RobiN
bij elke link geeft ie deze error:
RobiN
Geplaatst op: 28 Nov 2007, 20:47
ik bedoelde de site daar neer te zetten maar hij geeft dus een error dat hij het bestand niet kan vinden van webproxy.
Directe link zonder die proxy.
Dalijk even checken.
Misschien dalijk even op me eigen host pleuren die ik nooit gebruik .
[Laatst bewerkt door Maarten op woensdag 28 november 2007, om 20:50]
RobiN
Geplaatst op: 28 Nov 2007, 20:50
dank je deze werkt wel
Geplaatst op: 28 Nov 2007, 20:51
Die andere ook als je die link kopieerde die in dat balkje stond.
Maar dat snap je ook vanzelf als je die site gebruikt .
[Laatst bewerkt door Maarten op woensdag 28 november 2007, om 20:51]
Geplaatst op: 28 Nov 2007, 20:52
Ze werken allemaal weer Had ze nog niet gecontroleerd via die proxy.
Maar zijn nu directe links.
[Laatst bewerkt door DayDreamer op woensdag 28 november 2007, om 20:52]
Geplaatst op: 28 Nov 2007, 21:04
Momenteel ook even een mirror aan het maken.
[url]http://gabbers4life.nl/WLM9Beta.rar[/url]
Nog eentje .
[Laatst bewerkt door Maarten op woensdag 28 november 2007, om 21:08]
Alex
Kansloos
Geplaatst op: 28 Nov 2007, 21:19
Zal wel weer zo een gare kutbeta zijn waar de helft niet van werkt. Vind het ook vreemd dat er nu al een beta van is uitgelekt..
Nee, ik wacht wel tot een latere beta.
Ruttie
Heeft gesproken.
Geplaatst op: 28 Nov 2007, 22:11
Ik werk zelfs nog met 8.1.
Maar, als ik tijd en zin heb stap ik wel eens over op 8.5
Geplaatst op: 29 Nov 2007, 19:25
Ik nog altijd met 7.5 werkt prima.
Geplaatst op: 29 Nov 2007, 19:38
ik houdt het gewoon lekker bij 8.5, werkt lekker genoeg.
De beta van 8 was namelijk nou ook weer niet zo'n enorm succes.
Geplaatst op: 29 Nov 2007, 20:13
Geplaatst op: 29 Nov 2007, 20:28
Weet niet ?
Ik gebruik hem niet, Maarten volgens mij wel...
RobiN
Geplaatst op: 29 Nov 2007, 21:41
ik heb m wel al gedownload, maar nog niet geinstalleerd
is er een beetje vernieuwing in en werkt ie goed??
Geplaatst op: 30 Nov 2007, 07:25
Dit is nieuw
- Speciale geluiden instellen als een bepaald persoon online komt
- Bewegende .gif plaatjes als schermafbeelding
- Je kan jezelf op 2 plekken aanmelden zonder dat je word afgemeld op de andere plek
RobiN
Geplaatst op: 30 Nov 2007, 16:34
okeej dankje wel 'DayDreamer'
Stijnhau
worldwar.gamecoll.co
Geplaatst op: 30 Nov 2007, 17:52
je vergeet blokken en lid melden als spimmer he.
en inloggen is sneller.
onlangs er staat dat het trager is.
ik vind deze bete beter dan, msn 8.5 final.
enkel plus werkt niet maar er is al een hack voor.
en plus komt in december met v4.50 en di werkt volgend de beta tester wel.
KoiSashuu
Geplaatst op: 30 Nov 2007, 19:11
ik wacht op final
Geplaatst op: 30 Nov 2007, 19:36
Eventjes downloaden.
- Bewegende .gif plaatjes als schermafbeelding (Jippii! eindelijk een baby die ajax slaat als msn plaatje xD)
Naja, ik geef zo wel ff comment.
-comment-
Tot nu toe kut
Het inloggen duurt al 5 minuten ofzo
[Laatst bewerkt door Robertenzo op vrijdag 30 november 2007, om 19:43]
Geplaatst op: 30 Nov 2007, 20:20
Oke, helemaal fake .
Meld niet aan enzo
Krijg je error
Stijnhau
Geplaatst op: 30 Nov 2007, 20:23
raar.
ik log in met 64kbps per seconde en met 9.0 dan met 8.5 en met adsl.
jah belagacom heeft me weer eens van adsl afgehaalt zit over de 12 gig.
maar och nog sneller dzat is raar.
