CPU
Minimum: Pentium III or Athlon
You Have: AMD Sempron(tm) 2400+ PASS
CPU Speed
Minimum: 800 MHz
You Have: 1.67 GHz Performance Rated at 2.40 GHz PASS
System RAM
Minimum: 128 MB
You Have: 223.5 MB PASS
Operating System
Minimum: Windows 98/ME/2000/XP (95 & NT not supported)
You Have: Microsoft Windows XP Professional Service Pack 2 (Build 2600) PASS
Video Card
Minimum: 32 MB 100% DirectX 9.0b compatible Video Card with Hardware T&L
You Have: VIA/S3G UniChrome IGP (VIA/S3G UniChrome IGP) FAIL: Sorry, your video card does not meet this minimum requirement. Upgrade to a more powerful video card will make all your applications look better. Click the 'We Recommend' button to see some great options.
Video Card Features - Minimum attributes of your Video Card Video RAM: Required - 32 MB , You have - 32.0 MB
Video Card 3D Acceleration: Required - Yes , You have - Yes
Video HW Transform & Lighting: Required - Yes , You have - No
Video Card Driver Version (DirectX)
Your driver version number is: 6.14.10.113 FYI: Your video card driver version is provided for your information, but it is not part of this analysis. But proper video card driver versions are important to the proper operation of your product.
DirectX Version
Minimum: 9.0c (included)
You Have: 9.0c PASS
Sound Card
Minimum: Yes
You Have: Standaardspelpoort PASS
Sound Card Driver Version
Your driver version number is: 5.0.0.0 FYI: Your sound card driver version is provided for your information, but it is not part of this analysis. But proper sound card driver versions are important to the proper operation of your product.
Free Disk Space
Minimum: 1150 MB uncompressed (plus 400Mb for swap file in Win 98/ME or 600 MB in Win 2000/XP)
You Have: 51.1 GB PASS
CD
Minimum: 8X Speed CD/DVD ROM
You Have: HP CD-Writer+ 9300 PASS, but the Speed could NOT be analyzed.
Dat had ik uit de CoD Uo
weet iemand wat Video HW Transform & Lighting: is?
