Hoi mensen.
Ik krijg sinds COD2 opnieuw geinstallt te hebben deze errors van Xfire:
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
<?xml version="1.0" encoding="utf-8" ?>
<ExceptionReport Version="4">
<Application Build="29828" Command=""c:\program files\activision\call of duty 2\CoD2MP_s.exe" +set fx_sort 1 +set name ^5(clan?) ^1.^7D^9ie^7H^9ard^1. +cg_drawfps 1 +connect 145.37.208.246:28961"/>
<OperatingSystem Type="2"><Version Major="5" Minor="1" Build="2600"/></OperatingSystem>
<Exception Code="C0000005" Address="7E420010"></Exception>
<Registers EAX="6D3443FC" EBX="00000000" ECX="7E420010" EDX="00000003" ESI="000F8760" EDI="00000001" CS="001B" EIP="7E420010" SS="0023" ESP="0006E904" EBP="0006E914" DS="0023" ES="0023" FS="003B" GS="0000" Flags="00210202"/>
<BackTrace>
<Frame ProgramCounter="7E420010" StackAddress="0006E904" FrameAddress="0006E900">
</Frame>
<Frame ProgramCounter="6D33FF10" StackAddress="0006E904" FrameAddress="0006E914">
<Module Section="0001" Offset="0001EF10" FileName="C:\WINDOWS\system32\dinput8.dll"/>
<StackHexDump From="0006E900" To="0006E914">00 00 00 00 10 ff 33 6d fc 43 34 6d 01 00 00 00 0c 00 00 00</StackHexDump>
</Frame>
<Frame ProgramCounter="6D329EC2" StackAddress="0006E904" FrameAddress="0006E934">
<Module Section="0001" Offset="00008EC2" FileName="C:\WINDOWS\system32\dinput8.dll"/>
<StackHexDump From="0006E914" To="0006E934">34 e9 06 00 c2 9e 32 6d 01 00 00 00 90 02 0b 00 7a 97 80 7c 50 80 0f 00 01 00 00 00 00 00 00 00</StackHexDump>
</Frame>
<Frame ProgramCounter="6D32AD5E" StackAddress="0006E904" FrameAddress="0006E94C">
<Module Section="0001" Offset="00009D5E" FileName="C:\WINDOWS\system32\dinput8.dll"/>
<StackHexDump From="0006E934" To="0006E94C">4c e9 06 00 5e ad 32 6d 58 87 0f 00 00 00 00 00 00 00 00 00 00 00 00 00</StackHexDump>
</Frame>
<Frame ProgramCounter="6D32976C" StackAddress="0006E904" FrameAddress="0006E964">
<Module Section="0001" Offset="0000876C" FileName="C:\WINDOWS\system32\dinput8.dll"/>
<StackHexDump From="0006E94C" To="0006E964">64 e9 06 00 6c 97 32 6d 50 80 0f 00 00 00 00 00 00 00 00 00 58 2e 09 00</StackHexDump>
</Frame>
<Frame ProgramCounter="6D329825" StackAddress="0006E904" FrameAddress="0006E974">
<Module Section="0001" Offset="00008825" FileName="C:\WINDOWS\system32\dinput8.dll"/>
<StackHexDump From="0006E964" To="0006E974">74 e9 06 00 25 98 32 6d 50 80 0f 00 00 00 00 00</StackHexDump>
</Frame>
<Frame ProgramCounter="6D32D2EF" StackAddress="0006E904" FrameAddress="0006E980">
<Module Section="0001" Offset="0000C2EF" FileName="C:\WINDOWS\system32\dinput8.dll"/>
<StackHexDump From="0006E974" To="0006E980">80 e9 06 00 ef d2 32 6d 88 e9 06 00</StackHexDump>
</Frame>
<Frame ProgramCounter="6D3249AB" StackAddress="0006E904" FrameAddress="0006E990">
<Module Section="0001" Offset="000039AB" FileName="C:\WINDOWS\system32\dinput8.dll"/>
<StackHexDump From="0006E980" To="0006E990">90 e9 06 00 ab 49 32 6d 50 80 0f 00 58 2e 09 00</StackHexDump>
</Frame>
<Frame ProgramCounter="6D324A96" StackAddress="0006E904" FrameAddress="0006E9A8">
<Module Section="0001" Offset="00003A96" FileName="C:\WINDOWS\system32\dinput8.dll"/>
<StackHexDump From="0006E990" To="0006E9A8">a8 e9 06 00 96 4a 32 6d 58 2e 09 00 7a 97 80 7c 58 2e 09 00 4c 2e 09 00</StackHexDump>
</Frame>
<Frame ProgramCounter="6D325C65" StackAddress="0006E904" FrameAddress="0006E9B8">
<Module Section="0001" Offset="00004C65" FileName="C:\WINDOWS\system32\dinput8.dll"/>
<StackHexDump From="0006E9A8" To="0006E9B8">b8 e9 06 00 65 5c 32 6d 58 2e 09 00 58 2e 09 00</StackHexDump>
</Frame>
<Frame ProgramCounter="6D322F77" StackAddress="0006E904" FrameAddress="0006E9D0">
<Module Section="0001" Offset="00001F77" FileName="C:\WINDOWS\system32\dinput8.dll"/>
<StackHexDump From="0006E9B8" To="0006E9D0">d0 e9 06 00 77 2f 32 6d 58 2e 09 00 fc ee f8 01 54 2e 09 00 00 00 00 00</StackHexDump>
</Frame>
<Frame ProgramCounter="6D3231A6" StackAddress="0006E904" FrameAddress="0006E9E0">
<Module Section="0001" Offset="000021A6" FileName="C:\WINDOWS\system32\dinput8.dll"/>
<StackHexDump From="0006E9D0" To="0006E9E0">e0 e9 06 00 a6 31 32 6d 54 2e 09 00 e0 d7 3d 00</StackHexDump>
</Frame>
<Frame ProgramCounter="01F0154F" StackAddress="0006E904" FrameAddress="0006E9F8">
<Module Section="0001" Offset="0002054F" FileName="C:\Program Files\Xfire\xfire_toucan_29828.dll"/>
<StackHexDump From="0006E9E0" To="0006E9F8">f8 e9 06 00 4f 15 f0 01 58 2e 09 00 e0 d7 3d 00 36 19 f0 01 c0 eb f8 01</StackHexDump>
</Frame>
<Frame ProgramCounter="01EF90F0" StackAddress="0006E904" FrameAddress="0006EA1C">
<Module Section="0001" Offset="000180F0" FileName="C:\Program Files\Xfire\xfire_toucan_29828.dll"/>
<StackHexDump From="0006E9F8" To="0006EA1C">1c ea 06 00 f0 90 ef 01 01 00 00 00 00 00 00 00 d8 31 18 00 00 00 ee 01 38 eb 06 00 3e 98 ef 01 00 00 ee 01</StackHexDump>
</Frame>
<Frame ProgramCounter="01F1F83E" StackAddress="0006E904" FrameAddress="0006EB38">
<Module Section="0001" Offset="0003E83E" FileName="C:\Program Files\Xfire\xfire_toucan_29828.dll"/>
<StackHexDump From="0006EA1C" To="0006EA9C">38 eb 06 00 3e f8 f1 01 00 00 00 00 7d 28 f0 01 4c eb 06 00 70 ea 06 00 18 ee 90 7c 00 00 08 00 ff ff ff ff 6d 05 91 7c e0 cd 3d 00 00 00 00 00 40 00 00 00 4c 70 01 01 0f 00 00 00 00 02 3d 00 ff ff ff ff 88 00 00 00 18 ee 90 7c 70 05 91 7c ff ff ff ff 6d 05 91 7c 62 19 91 7c 93 19 91 7c 80 c0 97 7c 70 19 91 7c 40 a2 08 00 00 00 3d 00 2c 19 24 61 00 f0 fd 7f 84 ea 06 00 00 00 00 00</StackHexDump>
</Frame>
<Frame ProgramCounter="7C9011A7" StackAddress="0006E904" FrameAddress="0006EB58">
<Module Section="0001" Offset="000001A7" FileName="C:\WINDOWS\system32\ntdll.dll"/>
<StackHexDump From="0006EB38" To="0006EB58">58 eb 06 00 a7 11 90 7c 00 00 ee 01 00 00 00 00 01 00 00 00 d8 31 18 00 00 00 00 00 80 30 18 00</StackHexDump>
</Frame>
<Frame ProgramCounter="7C923F31" StackAddress="0006E904" FrameAddress="0006EBDC">
<Module Section="0001" Offset="00022F31" FileName="C:\WINDOWS\system32\ntdll.dll"/>
<StackHexDump From="0006EB58" To="0006EBD8">dc eb 06 00 31 3f 92 7c c8 27 f0 01 00 00 ee 01 00 00 00 00 01 00 00 00 00 00 00 00 8e e8 90 7c 00 00 00 00 14 00 00 00 01 00 00 00 00 00 00 00 78 de 08 00 00 00 00 00 00 00 00 00 00 00 00 00 f4 ea 01 01 0b 00 00 00 45 09 91 7c 4e 09 91 7c 00 00 00 00 01 00 00 00 80 30 18 00 00 f0 fd 7f 00 d0 fd 7f c8 27 f0 01 d8 31 18 00 70 eb 06 00 28 e5 06 00 c0 ec 06 00 18 ee 90 7c 98 3e 92 7c</StackHexDump>
</Frame>
<Frame ProgramCounter="7C81CD76" StackAddress="0006E904" FrameAddress="0006ECD0">
<Module Section="0001" Offset="0001BD76" FileName="C:\WINDOWS\system32\kernel32.dll"/>
<StackHexDump From="0006EBDC" To="0006EC5C">d0 ec 06 00 76 cd 81 7c 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 d1 0f 14 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 10 00 00 00 88 c1 97 7c 14 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 10 00 00 00 20 4e 18 00 c0 4f 18 00 ec 4f 18 00 00 00 00 00 48 b9 67 02 00 00 00 00 a4 1e 18 00 00 f0 fd 7f a4 1e 18 00 78 01 df 01 ec 4f 18 00 b0 4f 18 00 6c 52 18 00 10 4e 18 00</StackHexDump>
</Frame>
<Frame ProgramCounter="7C81CDEE" StackAddress="0006E904" FrameAddress="0006ECE4">
<Module Section="0001" Offset="0001BDEE" FileName="C:\WINDOWS\system32\kernel32.dll"/>
<StackHexDump From="0006ECD0" To="0006ECE4">e4 ec 06 00 ee cd 81 7c 00 00 00 00 b0 f3 e8 77 ff ff ff ff</StackHexDump>
</Frame>
<Frame ProgramCounter="0057CF24" StackAddress="0006E904" FrameAddress="0006ED1C">
<Module Section="0001" Offset="0017BF24" FileName="c:\program files\activision\call of duty 2\CoD2MP_s.exe"/>
<StackHexDump From="0006ECE4" To="0006ED1C">1c ed 06 00 24 cf 57 00 00 00 00 00 81 d0 57 00 00 00 00 00 88 3a 1d 02 c0 26 43 00 00 00 00 00 f8 ec 06 00 28 e5 06 00 b0 ff 06 00 f8 1a 58 00 30 92 59 00 ff ff ff ff</StackHexDump>
</Frame>
<Frame ProgramCounter="0057D0A7" StackAddress="0006E904" FrameAddress="0006ED68">
<Module Section="0001" Offset="0017C0A7" FileName="c:\program files\activision\call of duty 2\CoD2MP_s.exe"/>
<StackHexDump From="0006ED1C" To="0006ED68">68 ed 06 00 a7 d0 57 00 00 00 00 00 00 00 00 00 00 00 00 00 49 59 46 00 00 00 00 00 80 82 b1 00 ef 15 42 00 6c ed 06 00 84 7a b0 00 14 00 00 00 00 00 00 00 d9 0c 42 00 68 ed 06 00 0b 00 00 00 d4 03 00 00 42 24 80 7c 00 00 00 00</StackHexDump>
</Frame>
<Frame ProgramCounter="006E0000" StackAddress="0006E904" FrameAddress="74697571">
<Module Section="0003" Offset="00115000" FileName="c:\program files\activision\call of duty 2\CoD2MP_s.exe"/>
<StackHexDump From="0006ED68" To="0006EDE8">71 75 69 74 00 00 6e 00 67 00 73 00 5c 00 41 00 70 00 70 00 6c 00 69 00 63 00 61 00 74 00 69 00 6f 00 6e 00 20 00 44 00 61 00 74 00 61 00 5c 00 4d 00 69 00 63 00 72 00 6f 00 73 00 6f 00 66 00 74 00 5c 00 57 00 61 00 6c 00 6c 00 70 00 61 00 70 00 65 00 c3 8c 39 7e fa 06 3a 7e 6f 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 58 17 0a 00 00 00 00 00 59 07 3a 7e 00 00 00 00 00 00 00 00</StackHexDump>
</Frame>
</BackTrace>
</ExceptionReport>
En daar hoort dit screentje bij:
Soms krijg ik ook nog een andere error maar die heb ik nu niet bij de hand.
Weet iemand waardoor dit komt?
Edit:
Deze krijg ik ook:
[Laatst bewerkt door Matt op zondag 24 februari 2008, om 15:08]
