G:/
Stijn
<b>Neuker</b>
Geplaatst op: 10 Jul 2008, 19:56
Hi,
Bij elk programma dat ik instaleer komt er op:
Error 1327. Invalid  Drive: G:\
En ik heb nog nooit drive G:\ gehad en dit is een programma dat ik installeer via me HDD.
Jesse
House<3
Geplaatst op: 10 Jul 2008, 20:05
Drive G: is misschien verwisselbare schijf ?
Stijn
<b>Neuker</b>
Geplaatst op: 10 Jul 2008, 20:10
Ja
Ik heb me usb stick maar eens G:\ genoemt en toen werkte ie
toch bedankt
Jesse
House<3
Geplaatst op: 10 Jul 2008, 20:20
Radiozone schreef:
Ja
toch bedankt
No problem
Geplaatst op: 10 Jul 2008, 20:59
Jesse schreef:
No problem
Ja, alsof jij geholpen hebt. Su.
Probeer dit eens:
InstallShield.com schreef:
Verify that registry entries do not contain invalid drive letters that might be causing this error:
1. Click Start, and then click Run. The Run dialog box opens.
2. In the Open field, type regedit, and then click OK. The Registry Editor opens.
3. In the Registry Editor, locate the following registry key:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
4. In the right pane, note the values in the Data column of each entry. If any value contains a drive that is not correct for your computer, right-click the entry and select Modify.
5. Type the correct drive letter in the Value data field, and then click OK. For example, if one of the values is "X:\Documents and Settings\Administrator", the drive letter should be changed to a valid drive on the system, such as &#8220;C:\Documents and Settings\Administrator".
6. Repeat steps 4 and 5 for each entry whose Data value contains an incorrect drive.
7. Repeat steps 3 through 6 for each of the following registry keys:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
8. Close the Registry Editor and run the installation again.
Bron.
Volgende keer eerst de error Google'n.
Jesse
House<3
Geplaatst op: 10 Jul 2008, 21:17
Probeer dit eens:
Bron.
Toevallig wel noob
Niet omdat je admin bent dat je alles mag he
Geplaatst op: 10 Jul 2008, 23:38
Jesse schreef:
Toevallig wel noob
Ooooooooooo Myyyyyyy F.
Hoezo mag ik niet alles? HéleMAAL wel dat ik alles mag. Simpelweg omdat ik hier alles te zeggen heb over jou. Punt.
Ik zie ook absoluut geen link tussen alles mogen en mijn vorige reactie.
Ik mag WEL alles, en toch zal ik me dit keer inhouden en je gewoon weg laten lopen. Ik raad je aan dit ook te doen, sinds je al niet zo geliefd bent bij meerdere mensen.
Jesse
House<3
Geplaatst op: 11 Jul 2008, 12:43
Oké dan maar
[Laatst bewerkt door Jesse op vrijdag 11 juli 2008, om 13:46]
